Autometer 12v Boost gauge
Old Sep 27, 2007 | 12:10 PM
h.funk's Avatar
I cant seem to find the correct wire under the dash to power the gauge. I have tried a constant power source and it dosent work. I have read that i need to use a ignition wire. But looking under the dash i see many blue and white wires. I have all the vac. lines hooked up but the gauge dosent move at all when i try pluging it in to a power source. Help on the correct wire to use.
Thanks
Old Sep 27, 2007 | 01:30 PM
h.funk's Avatar
I have tryed black and gold = no good.
tryed white and blue = no good.
tryed moving the ground = no good.
Help
Old Sep 27, 2007 | 01:40 PM
05blue8's Avatar
Pink wire...I'm pretty sure in the ignition harness there is a pink wire that gets power on ignition that my gauges are running off of. I'll double check in about an hour when I go to my car.
Old Sep 27, 2007 | 01:46 PM
h.funk's Avatar
Thanks for the help. Autometer said that it has to be a non constant power source. One that doesnt get cut off a ignition.
Old Sep 27, 2007 | 04:25 PM
PANGES's Avatar
Get some fuse taps from autozone or kragen or whatever and get the power through the ignition fuse in the block of fuses behind your dimmer switch.
