Mini Battery/Stereo
Old Nov 27, 2007 | 04:03 PM
RyanEvo2006's Avatar
Mini Battery/Stereo
I really want to get a mini battery kit so I can run a shorter UICP but the thing is I dont want to get rid of my stereo. Right now I have two amps one running a 12" sub and another running a set of components up front. How much power can a mini battery hold ? Im not going to be playing the stereo with the car off ever but will it have enough crank to start the car + stereo in northeastern PA winters ??
Old Nov 27, 2007 | 04:10 PM
2 Deep Motoring's Avatar
i have the full ETS kit w/ the mini battery and i am using a 450w amp to power my components and a 300w amp to run a 10" type s... i listen to alot of rap and when the bass hits my volt meter dips all the way to 12.5... i would just use your stock battery and mount it to the rear and power your stereo that way
Old Nov 27, 2007 | 05:48 PM
atombomb33's Avatar
EvoM Community Team
You can make a mini battery work. There are several Braile models that have high cranking amps that would work. BUT, you need to get a higher output alternator. Otherwise, you're mini battery will go flat relatively quickly and you'll need a new battery. So, it can be done. Look for post by a member named TempeRacerGuy. He's using a mini battery with 3 amps...he's also upgrading his alternator so he doesn't kill his battery.
Old Nov 27, 2007 | 06:38 PM
TempeRacerGuy's Avatar
mini battery + bangin' stereo system = issues
mini battery + bangin' stereo system +high output alternator = zero problems
