?? rear window wipers dont work...
Old Dec 7, 2007 | 07:14 PM
mlancerevo8's Avatar
hey i have a problem i installed a deck in my evo and then something went wrong with my remote on my deck and since that happened i dont have my clock my remote on my deck and my rear windshield wipers... need help to find the problem
Old Dec 20, 2007 | 06:50 PM
eclipsegsx012's Avatar
if you could get your hands on wiring diagram see if the if remote for the rear wiper and clock is sharing the same fuse. First thing i would look at is the fuse.
Old Dec 21, 2007 | 06:31 PM
funny thing is all the fuses are good... i switched them all out... and none of the relays are bad... i got the wireing diagram but im not sure where to start... the washer dont spray either,,,,
Old Dec 22, 2007 | 05:36 AM
redlaybal's Avatar
did u check the motor? could be some kinda defect
Old Dec 22, 2007 | 04:01 PM
where you get the wiring diagram? i mean if you could send it to my email i could check it out. But where you could start is to check if the the clock remote and rear winshield wiper is sharing same power source or ground. If they do i would start with checking the power source, if you have good source voltage check the ground is the next thing you should do.
If you can send the wiring diagram email it to me @ eclipsegsx012@gmail.com
Old Dec 22, 2007 | 04:02 PM
If it was the motor only rear winshield wiper won't work
Old Dec 23, 2007 | 06:05 AM
Appauldd's Avatar
There is a yellow fuse holder in the engine bay. It holds 2 fuses. You have to pull the yellow holder up and then use needle nose plyers to get the fuses out. I had this same problem and the fuse here was blown.
Give it a try.
Old Dec 23, 2007 | 06:30 AM
Curt@MrLed's Avatar
Former Vendor
well its either coincidence or your really bad at wiring stuff.. retrace your wiring.
Old Dec 23, 2007 | 12:57 PM
KcEvil8's Avatar
Give it a try.
+1....happen to me too
Old Dec 25, 2007 | 05:17 PM
i found it out what the problem was it was my deck remote didnt work soo somwhere on that wire it ties into the rear windsheild wiper... soo i hooked it up with a different signal wire and i got it all working...
Old Dec 26, 2007 | 06:50 PM
different signal wire you mean power wire rite?
Old Dec 30, 2007 | 10:07 PM
well its not really a power wire... in a way it does push 12v but it connects between the switch and the motor... because i had power at the switch and at the motor...
Old Dec 31, 2007 | 03:11 AM
How many wire is there? if there is two it is either power or ground and the switch might be ground sided. If you follow the wiring diagram you should either see the switch on the power side or ground side. Since you know the problem now, you need to replace the wire.
Good luck
Old Jan 1, 2008 | 05:42 PM
alright i got another good one... well ook my ignition switch is messed up... the switch on the column says my key is always in the ignition... its a lil white box on the back side of the ignition switch... is there any way i can bypass the switch...
Old Jan 1, 2008 | 08:06 PM
damn what did you do to cause all this electric problem?? i'll try to get wiring diagram at school and check it out for you
