How to ensure an Amp will receive 14.4 volts?
Old Feb 1, 2008 | 04:09 PM
Inprogress's Avatar
I will have 2 amps, the Alpine MRP-M450 and MRP-F450
the mono is 400 x 1 @ 2ohm 14.4
the 4 channel is 70 x 4 @ 4 ohm
I'll also be adding an Optima Red Top in the trunk and removing the minibattery
Old Feb 2, 2008 | 03:54 PM
ddubdb3's Avatar
yea ive had a $200 stinger cap on my system thinkin that would be the cure for the lights dimming only to be out $200 cause it did nothing..a new alt would be the way to go..im also thinkin about a batcap battery anybody tried out one of these??
Old Feb 2, 2008 | 04:28 PM
igo4bmx's Avatar
Originally Posted by Inprogress
I really can't afford the alternator right now, it's on my list and at the top too for that matter. I just wanted to know if in terms of an optima battery, a cap, and proper wiring, if that would suffice to get the voltage up to 14.4 consistently.
your car runs on battery when the car is not running- so there is really no benefit (besides cranking power and energy while alt is off) for a battery.
http://www.bcae1.com/charging.htm
Old Feb 2, 2008 | 08:59 PM
Inprogress's Avatar
So you're saying there's no point in upgrading the battery? What would it help with then?
Old Feb 3, 2008 | 01:35 PM
Inprogress's Avatar
No one have an answer to what I asked above?
Old Feb 3, 2008 | 01:53 PM
diablo2184's Avatar
the stock electrical system sucks doesnt it? at least mine does....the dash dims when i try to put more than 1 window up. anyone have the same problem? what should i do for that? battery, grounding kit, HO alternator?
Old Feb 4, 2008 | 09:29 AM
spooch's Avatar
definately pick up an iraggi ho alternator, my friend put one in his and it cured all the power problems he had due to running dual 2400 rms mono amps...
Old Feb 4, 2008 | 10:19 AM
matt55's Avatar
Over kill for a 400 watt amp ,
Yes a bigger/better/more batt(s) and upgraded Alt will help , but you will spend more $$ on Alt and batt that you have in the amp .
caps are crap
The best way to insure you have a soild 14.4v is start with 16v (16v batt and Alt pumping out 16-17 volts) but thats over kill again .
Btw I ran for years 6 SVR 12v batts , 4 MMATS D100's(around 2000w each) , 6 Stroker 15's , 160+dbs all on the STOCK S-10 100amp Alt .
Red top in the rear will work out great for you set up !
Old Feb 4, 2008 | 10:49 AM
Inprogress's Avatar
Sweet! Yeah I'm getting the higher output redtop, I believe its 1000 CA and 800 ColdCA
So that should be plenty! I contacted the ebay store that was posted in this thread for alternators and the said they don't have any for the Evo application. I guess I'll just wait and see what happens, hopefully I won't need one!
Old Feb 4, 2008 | 02:19 PM
spooch's Avatar
You wont need one for your small amount of power being used, but down the road when you upgrade to a bigger setup it wont hurt
Old Feb 4, 2008 | 07:36 PM
felickz's Avatar
Better battery will ensure that when you play your system with the ignition off you wont have a dead battery so quick.
Old Feb 12, 2008 | 04:31 PM
gsrtroy's Avatar
i have been installing systems in cars for over 5 years, and i can tell you instead of the red top batt. get the yellow, way better for what the amp takes away. i believe though it should be fine, 500rms is not to high, i run 2000rms in my jeep with just the yellow top battery and i have no issues what so ever my voltage drop to 13.8 at the most.
if the voltage on any car were to drop below 11.5 volts then you would probably start blowing fuses out.
also capacitors are a waste, never buy one.
Old Feb 12, 2008 | 07:41 PM
Inprogress's Avatar
I have been trying to get in contact with D. Iraqqi, but have had no luck. I contacted his ebay store and was given an abrupt "No, we don't have any for your model car" and I emailed him directly at his own email adress last friday and haven't heard back.
I did end up getting different amp...
MRP-M850 = 800 watts rms @ 2ohm x 1 @ 14.4
MRP-F450 = 70 watts rms @ 4ohm x 4 @ 14.4
I also bought the optima redtop, the only yellow tops that are better then the red tops are the ones that are $250+, I got the best redtop, 800 Cold Cranking amps and 1000 cranking amps, for $134 locally.
Old Feb 13, 2008 | 07:52 AM
gsrtroy's Avatar
still, should be fine, if you experience any dimming, then pm me and i can give you a link on how to do the "big 3" if you know what that is.
Old Feb 13, 2008 | 09:05 AM
Inprogress's Avatar
yeah I know what it is, im just interested to see how that can be done with the battery in the trunk you know? Mainly the power source for the alternator.
