Need help with grounding HU. Please
When I had my stereo installed in my IX, I attached the ground to a bolt that is part of the metal framing that is directly behind the head unit. There is one bolt to the left and one to the right. 10MM bolts if I remember correctly. Those will work for you. Hopefully my description will help you find them.
