Compustar turbo timer
Old Apr 27, 2008 | 06:09 AM
navysandsquid's Avatar
for some reason when I try to set the turbo timer it says FAIL. any Ideas what I'm doing wrong
Old Apr 27, 2008 | 06:12 AM
sblvro's Avatar
are you installing or you have a compustar with built in tt and trying to use it? did you do the reservation mode?
Old Apr 27, 2008 | 06:23 AM
I have turbo timer when I hit the iii + iv button it beeps 3 times and says fail. Reservation mode?
the installer said he hooked up the wires for it and they read good so I'm not sure
Old Apr 28, 2008 | 12:18 PM
sblvro's Avatar
to check if your reservation mode is active is after you stop the vehicle, raise the e-brake and don't press on the brake pedal, with the gear in neutral take the key out. at this point the engine should be running. get out of the car with the engine still running. if turbo timer is off, as soon as you close the driver door shut, the alarm arms itself, powerlocks all doors and turns the engine off. if turbo timer is on, the engine continues to run even after you close the driver door. you have to arm the alarm by pressing I and it should chirp-still with engine running. press and hold II(not immediately) if you want the car to remotely start.
Freddy302
Oct 11, 2016 05:55 PM
Jake26
Feb 23, 2011 03:02 PM
Evo442
Mar 28, 2004 04:32 PM
Evo11V
Oct 15, 2003 06:56 PM
rexhunta
Jun 24, 2003 08:10 PM
