Mini Battery question
Old Jun 1, 2008 | 03:29 PM
stev08's Avatar
Do mini batterys work well with sound systems? I'm not finding anything in searching so far, but as of now I have an amp w/ 2 12's in the trunk w/o a capacitor, definately going to be getting a cap and either going to only 1 12 or 10" for room. Just wondering if mini batterys can support something like that.
Old Jun 8, 2008 | 05:18 PM
SHhhhh's Avatar
bump
anyone?
Old Jun 8, 2008 | 05:21 PM
bluebyu36's Avatar
no, they dont work good with out systems they suck
Old Jun 8, 2008 | 05:44 PM
ApacheFixer's Avatar
thats when you should just relocate to the trunk
Old Jun 8, 2008 | 08:08 PM
stev08's Avatar
Yeah my battery is already relocated to the trunk but the relocation kit that was done by the previous owner is cheap and looks to be only 2 gauge wire with a 100amp fuse and that fuse has blown on me numerous times. One time when I stalled it blew, one time when I was fixing a fuel pump problem and had to crank it alot it blew. So I think my alternative to the mini battery is just running 0 gauge wire with no fuse. What do you guys think? It still has factory fuses from the battery terminals up front I believe.
Old Jun 8, 2008 | 08:29 PM
nothere's Avatar
I ran a 0 gauge wire up to the front. Needed to put a wire distributer block up there.
A large fuse in the back by the battery. Also ran a dedicated ground to the front.
Have since gone to a mini battery, but with the big wire the stock battery was strong.
Old Jun 8, 2008 | 08:37 PM
Jasil's Avatar
Mine does fine never drops below 12v in the DAY without lights. At night with lights the volume has to be much much lower. Still a huge improvement over stock, but can't really crank it either.
I'm running 4 Boston Pro60's a JL12W6v2 in a Audio integrations box pushed by a RF 25 to Life amp about 1000W RMS.
Old Jun 9, 2008 | 12:21 AM
Jspec EVO VIII's Avatar
Do mini batteries work well w/the stock SSL sub? I'm looking into upgrading my pipes and wanted a mini battery but worried about this as well.
Old Jun 9, 2008 | 06:47 PM
biggie5252's Avatar
With the factory system I'd think you'd be ok.
Old Jun 22, 2008 | 08:35 PM
VRSF Tiago's Avatar
So even if I were to get like a 5 farad cap, a 400 watt mono amp & 400 watt 4 channel would overload a mini battery?
Old Jun 25, 2008 | 05:50 AM
Jasil's Avatar
Caps are worthless!!! You would see significant dimming at night if those are true RMS numbers.
Old Jun 25, 2008 | 06:07 AM
VRSF Tiago's Avatar
Battery relocation it is!
