Electrical problem...please help!
Old Jun 10, 2008 | 07:33 AM
Todd06MR's Avatar
OK here is the backround.
I was driving down the road and came upon some construction. I was forced to drive over the road edge/anti-sleep/rumble strip (whatever it is) on the edge of the highway. When I did, the entire electrical system shut off. Lights, engine, radio, everything went off for only a second. Then it came right back on. I thought it was jsut a loose wire because I have a battery relocation kit. I checked the connections and they are all good.
But now, the car only charges at 12 volts (not 14). Everything I do (radio, fan, lights) brings the voltage down. But when I turn that stuff back off, the voltage runs back up to 12.
I don't know if it is a battery problem, a voltage regulator problem, or faulty wiring.
Please help.
Old Jun 10, 2008 | 08:05 PM
Evo8zip's Avatar
look at the "electrical gremlins" sticky in this section
and if that turns out to be your problem, please follow the link i provided to file a complaint with the NHTSA so we can get a remedy to this problem
Old Jun 11, 2008 | 12:28 AM
EvoKnievo's Avatar
yikes!
glad you and your evo survived
the only electrical stuff we have underneath our cars is the alternator wire, that would be the first place to start your mission.
just get a d bomb and start from there, im sure your going to want to look over everything after going over something that severe
