Need help!!! Evo having weird symptoms!!!!
Old Jan 16, 2009 | 11:33 AM
scumrat's Avatar
solved!
Old Jan 16, 2009 | 01:02 PM
gsrboi80's Avatar
You likely hit the starter with your screw driver. Looks like something to your ignition took a hit or is loose
Old Jan 16, 2009 | 01:06 PM
scumrat's Avatar
bump!
Old Jan 16, 2009 | 01:08 PM
Mr. Evo IX's Avatar
Get your battery and alternator tested, make sure your battery terminals are tight. Is the car starting now under it's own battery power?
Old Jan 16, 2009 | 01:12 PM
scumrat's Avatar
i got gas and it started right up, but its been sitting for a couple hours now and i havent tried to start it again.
Old Jan 16, 2009 | 01:13 PM
scumrat's Avatar
whats weird is that it would jerk hard when i hit around 5lbs of boost and above, also it turns off and on really quick while im driving.How would electrical effect the boost problem?
Old Jan 16, 2009 | 02:03 PM
Mr. Evo IX's Avatar
The boost problem is probably related to the LICP. Make sure its on good and tight and no leaks.
Old Jan 16, 2009 | 03:24 PM
scumrat's Avatar
the licp is fully tight and on perfect, and right after i installed it i drove it hard and it was fine.The next day it wouldnt start and then the car reacts weird to the boost so i dont know what the hell is wrong!
Old Feb 11, 2009 | 02:48 AM
D420mac's Avatar
I had a similar issue on my IX. I hit a deer with my car it has been fixed, but since then the battery is continually draining. I have replaced the battey twice, Very costly. It runs fine once it's started and running.
When I get into it and it really boosts I notice my gauges dim, usually about the same time My wastegate is open and my alcohol is injecting. one time I stalled it out accidentally and it wouldn't start, like no battery the gauges barely even lit the battery voltage was below 9V. Jumped it and it made it home.
When I shut it down usually it'll start right back up. but if it sit's for three days or so it'll die and need to be jumped. then while running the gauges and lights will dim but only while boosting. sometimes when I shut it off it will not start while other times it'll start right up.
It's really weird!! My car is in the shop now and they are supposed to be going over it.
