Sunroof Problem
Old Feb 10, 2009 | 03:10 PM
HarEvo's Avatar
Sunroof Problem
My Sunroof doesnt work at all.
I checked under the dash for the sunroof fuse and the fuse is still good. and even replaced it with a new fuse. Any suggestions as to what it might be?
thank you friends
Old Feb 19, 2009 | 07:59 AM
03nevaevolution's Avatar
Veteran: Army
thank you friends
does the sunroof move or make any sounds when button activated? if no sounds, its your motor! if makes sounds but doesn't move, its the cable for the sunroof to motor. I had similar issue where my sunroof was stuck. one of the screws that holds the motor up had loosened so that the splines weren't connecting with the cable to move sunroof. easiest acces from back seat!! Good luck!!
