SSL sound system breaking up at high volume
Old Apr 14, 2009 | 08:32 PM
BostonEvo's Avatar
Ok so i pulled the car apart today looking for a bad ground , Cuz Once you turn volume past 20-22 , It cuts out , Sounds like a bad ground. Cant find anything loose. Im kinda stumped. So im gussing the amp is going or possibly the headunit's signal is clipping.
Any suggestions on how to narrow down what peice is going. Or any other suggestions on how to fix it
Old Apr 16, 2009 | 05:35 PM
BostonEvo's Avatar
Bump?
Old Apr 18, 2009 | 02:25 PM
MRCole's Avatar
Set all EQ's or treble and bass to 0, then try again. If it continues, ohm speakers out. Next, if they all read about the same, check for lose power, bad ground, partial blown fuse. If that's not it, bad amp.
Old Apr 18, 2009 | 08:32 PM
BostonEvo's Avatar
thx , i checked for lose grounds/power etc , ill try the fuse issue and the speakers , Easyest way to check speakers would to be from the amp input correct , or from the back of the radio? Instead of pulling the door panels off
Old Apr 18, 2009 | 09:38 PM
MRCole's Avatar
From the amp, to the speakers.
Old Apr 26, 2009 | 02:59 PM
BostonEvo's Avatar
Havnt had the chance to check speakers , but when i dail down the bass setting all the way , I can put it up much louder... Cuz its using less power i suppose... Seems like the amps going?
