Color match for interior a pilliars?
Im curious if anyone has matched the color to the stock interior a pilliars successfully? If so what paint did you use thanks
how does that look from the outside infront of the car?
does it look bulky at all (because the lighter colour pillar stands out than the black one)?
can you please take a picture?
I'm a body man. If your looking for a rattle can good luck. If you go to your closest Auto Value or parts store that sells Paint products for body shops they should be able to look up interior colors also. There are interior resins that are used for painting anything plastic or vynal. I have only used Dupont products so that's all I know. I forget the # on it but it's a vynal resin that can be bought in a high, med, or low gloss and the color is added to that. They should be able to mix it on the spot or give you the color formula. Then you would have to have it sprayed on but I can tell you all those steps too so all that you would need is to have it sprayed ant that's all they would have to do at the body shop. They cant charge you much for 30 min. of work and a couple hrs of dry time.
