How to know if your iac motor is bad.
Old Jan 2, 2010 | 10:23 AM
dipsetinallday's Avatar
If you dont hear the plunger or iac motor not move does that mean the iac motor is no good?
Old Jan 9, 2010 | 08:47 AM
SpoolinUp's Avatar
Silver Sponsor
Take it off. Check your ISC with a multimeter. Should be a consistent 28-33 ohms or so (varies with temp, as long as the numbers are all the same it is fine). Check pins 1&2 2&3 4&5 5&6.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 31, 2010 | 11:32 PM
GregM's Avatar
I checked mine and they all read 21 ohms, so abit lower then spec. My car dies when I put in gear and try and accelerate when cold. Its not all the time, but normally at least once a day.
Old Feb 4, 2010 | 05:07 PM
03blkevo's Avatar
The gears on the IAC motor might actually be stripped, (it happen to me) since the gear that spins those are metal it actually eats up the Plasitc one in the IAC
Old Feb 5, 2010 | 12:21 AM
VETTE_50_TH's Avatar
It should move. Best way to test that is to turn the car on with it out and see if it moves. Or if you put it to on, it should move in and out.
Raceghost
Jun 9, 2016 06:27 PM
4ukc
10
Dec 7, 2015 02:33 AM
bnice01
32
Sep 13, 2013 02:09 PM
Knightracer
11
Oct 13, 2012 05:30 AM
