CT9A's: Can I See Your Trunk Mounted Batteries?
Old Mar 12, 2010 | 04:31 AM
NJ9MR's Avatar
FCOTM Winner
[quote=06MREvo;8086760]NJ9MR post some pics once you get your trunk setup done...
You bet!Coming soon!
Old Mar 12, 2010 | 04:37 AM
SEEnoEVO's Avatar
I should have mine wrapped up this weekend and will snap some pictures as well.
Old Mar 16, 2010 | 04:39 PM
Jhutterer's Avatar
I am also looking to do this... The one picture was a very clean setup.
Old Feb 15, 2011 | 10:21 AM
SPANKED's Avatar
Originally Posted by Gordian79
Howie you can try a Mazda miata battery up front.It will probably clear short route pipe.They are small but bigger then mini battery kit ones.They pack full juice.I have an old one if you want to check fitment.If i were to go trunk would go with plastic box because they are smaller and makes for a cleaner install.
Gordian you have any info on how to make the Mazda miata battery work? Do i just go to a mazda dealer and pick one up plus the tray? Any info is appreciated. Thanks.
Old Apr 24, 2011 | 04:15 PM
Lolo La Torche's Avatar
I have the kit, I just wait for my car to come back from electro-doctor who will find my electrical leak I hope.
So, I'm interested in all photos you can show, especially where does the positive cable pass from the motorbay and threw interior
Tnahks in advance, this will help me next week end
Old Apr 24, 2011 | 04:40 PM
Evoardo IX's Avatar
I don't know if the OP still needs to see pics, but here's mine. I also have the full works trunk cage, and the reason I put the battery on the pass- side is because my car has the ACD pump on the driver's side, so it was impossible to drill/mount on that side.
[img]
Uploaded with ImageShack.us[/img]
Old Apr 24, 2011 | 05:33 PM
awdturbo8's Avatar
So you relocated your acd pump to the trunk??
Old Apr 24, 2011 | 05:53 PM
Evoardo IX's Avatar
Nope, JDM 9 RS, it comes like that from the factory, I have the IC spray bottle in the front, where the US spec evo has the acd pump
Old Apr 25, 2011 | 02:58 AM
You have European or Japanese Specs with ACD pump and liquid in the trunk( driver side) and water on the other side
Where did you pass you cables in the cockpit? Under the floor?how?
Thanks
Old Apr 25, 2011 | 05:44 AM
Evoardo IX's Avatar
Thanks
Ok I started with the positive in the engine bay, I routed it around the fusebox, into the fender and then I followed some other cables that go into the cabin through a grommet on the driver's foot well. Once I was in I followed all the side of the car under the door sills, went around the rear seat and into the trunk on the passenger side.
The negative I just used the OEM one I clipped off of the engine bay, and bolted it on the trunk really close to the terminal.
Old Apr 25, 2011 | 11:45 AM
Thanks my friend
How much time did you need to make this please? 4 hours?
Old Apr 25, 2011 | 11:57 AM
Evoardo IX's Avatar
yeas about that much, the hardest part is to pass the + wire through the grommet in the driver's side foot well... I used a 2 gauge wire, anything bigger than that might just be impossible haha, good luck
Old Apr 25, 2011 | 01:32 PM
I don't understand what a "2 gauge wire" is
Sorry for my english...
What you call grommet is the hole where cables are passing threw cabin?
Old Apr 25, 2011 | 01:42 PM
Evoardo IX's Avatar
Yes grommet is actually the rubber in the hole where the cables go into the cabin. 2 gauge wire is the thickness of the cable, the closer to 0 the bigger it is, i.e an 8 gauge wire is going to be much thinner than a 2 gauge. You actually need a thick wire for the positive since it will travel a long distance to the battery, also make sure you use quality cables.
Old Apr 25, 2011 | 01:46 PM
Thanks a lot for your answers
I use quality cables (25mm2) from a special relocation battery kit
