Radio does not work after gauge install
Old Mar 22, 2010 | 11:58 AM
MRmike's Avatar
I was wondering if I blew a fuse and which one I replace if I did. I tried hooking up a boost gauge today and got the gauge to light up, but as soon as I attached the sender power wire, my new boost gauge, radio, clock and stock gauges do not light up... Any tips? I used the blue/yellow 12v switched wire from the radio harness to wire the new gauge I was installing.
Old Mar 22, 2010 | 08:46 PM
MRmike's Avatar
Update: My stock gauges, hvac lights, hazard light all light up when I turn my headlights on, but still no radio.
Old Mar 25, 2010 | 09:10 AM
toxic-evo's Avatar
is ur deck in the dash? cause the deck grounds itself out on the metal where the deck sits. if its not grounded it will not turn on.
Old Mar 25, 2010 | 06:19 PM
BoostWhore's Avatar
The radio fuse are under the hood in the driverside fuse box... Theres two fuses that are grouped together in a little yellow holder. One of them should be the radio fuse check that.
