Switching turbo timers
Hey guys, in my evo now I have a GReddy turbo timer, it works perfectly fine and everything but I want to switch it out for an Apexi timer. I should just be able to cut the wires from the GReddy and connect the ones from the Apexi right? On the Apexi I dont plan on running the air fuel wire. So I would just have to hook up the ground, and run the e-brake wire. Then the 3 thicker wires to the 3 thicker wires on the GReddy. (constant red, ignition 1 green, and ignition 2 blue)? Thanks guys.
