Loose shift knob
Loose shift knob
hey guys, so im trying to remove my shift knob but the thing is loose on the inside and it just spins freely that its stuck and wont come off.. what can i do to take the knob off?
thanks
thanks
Is it a stock knob? If so it could be the leather wrap is spinning, mine did that. Can you pull the knob a little off center and try and slowly spin it that way? Like you are trying to cross thread it a little, but just putting pressure on one side while spinning it.
yeah its the stock knob, well when im trying to remove by twisting (counter wise) the whole knob just keep spining and it wont go up, like the tread is gone..its really annoying
any update on this? I have the same issue. I'll try to grab it tight and see if that stops it from rotating.
it's a little bit annoying. I'm fine with the stock knob otherwise, if I can fix it, I'll stick with it.
is the stitching real? was thinking maybe get a syringe and inject a little super glue in there.
there's absolutely nothing wrong with the stock shift knob in my mind... except for this.
DarkSyde294
Aug 15, 2013 09:52 PM
JerseyEvox
Evo X How Tos / Installations
24
Nov 14, 2012 09:26 AM
