Upgrading MR gauges to Defi's...
Old Apr 29, 2011 | 04:50 AM
QwikEVO's Avatar
...can I just unhook the Boost/Temp/Volt gauges and install the Defi gauges...pretty much plug and play?
Or do I need to make totally new connections?
Old Apr 29, 2011 | 06:25 AM
TTKID's Avatar
Pretty sure its not plug and play.
Old Apr 29, 2011 | 06:30 AM
Evo Tengoku's Avatar
Its not 100% plug and play. But if you pull out the oem gauges, you should see a wire harness that connects the gauges to the radio harness. Makes it easier to splice these wires instead of the radio wires. Also, you can use the vacuum line off the boost gauge for the Defi gauge.
Old Apr 29, 2011 | 06:47 AM
QwikEVO's Avatar
So where would you
A) get the signal for the voltage
b) get the signal for the temp
Old Apr 29, 2011 | 07:00 AM
Evoardo IX's Avatar
it's best to uninstall the OEM gauges and keep/sell them complete (wire harness and temp sensor).
DEFI's will work with their own sensors/senders for boost, oil temp, water temp, whatever gauge you buy. The voltage is fairly simple you just get the signal from a 12v source, i.e. where you would get the + for the gauge's lightning.
Old May 3, 2011 | 11:09 PM
cobb-sti's Avatar
^ do what he said^. Defi comes with every thing you need.
