Dry carbon..
Old May 5, 2011 | 11:53 PM
42revoincali's Avatar
Dry carbon..
Not sure if this belongs here but I am interested in some dry carbon products but the prices are ridiculous.
Is there a way to purchase a clear coated carbon hood and just strip the clear off of it? Im only doing it for looks nothing to save weight.
Any input is appreciated, call me a ricer but with an evo painted satin black, clear coated carbon just doesn't look right.
Old May 6, 2011 | 11:21 AM
Wrong section but mods can move to wherever they please.
Old May 6, 2011 | 11:29 AM
EvoJoeRacing's Avatar
Its a completely different process... dry carbon is not wet carbon with the clear coat removed
Old May 6, 2011 | 11:32 AM
Heres what a little google searching can do for you:
http://www.gruppemusa.com/2010/10/carbon-fiber-101/
Old May 6, 2011 | 09:06 PM
Thanks read through it a bit more, sorry to sound stupid still but can you remove the clear from the wet carbon hood and make it appear to be a dry carbon ?
Old May 7, 2011 | 12:08 AM
KevinD's Avatar
no, "wet carbon" finish looks glossy because of the excessive use of epoxy and resins. without it, it would be like fabric. the dry carbon is also called pre-preg carbon because it comes with the epoxy resins already embedded in it in the perfect amount. no need to soak it. its insanely expensive because it takes a lot longer to get it perfect, and the material is a lot more expensive. i have a dry carbon hood we wanted to make for people but it wasnt worth it for 3-4 people. so there are two hoods in dallas and thats it
Old May 7, 2011 | 12:37 AM
deylag's Avatar
You could use this instead. Its called 3m dinoc vinyl. It has a flat dry carbon look. You can wrap it onto hoods, trunks, roofs and practically anything that has a clean surface.
Let me know if you need some. I can get you any quantity at a price lower than competitors.
Old May 15, 2011 | 10:16 AM
turbophile's Avatar
What's the best way to wrap stuff, do you wet it with soapy water first or stretch it with heat gun? Just got some but so far I'm sh*t at wrapping.Thanks
Old May 15, 2011 | 02:52 PM
4G63kevin's Avatar
^ Clean the area first. Then you can apply. It's fairly simple imo. Just takes lots of patience.
Old May 16, 2011 | 06:56 PM
deylag's Avatar
Soapy water will leave residue. I would use 70% rubbing alcohol. Wipe down all the surfaces you plan to cover. It dries itself and leaves no residue.
Do not use the heat gun a lot. It will warp the DINOC. You will want to use just a little heat if you have trouble with it. One quick pass of the heat gun at maximum.
Hold off your installation and wait for a hot day. Like 80 degrees Fahrenheit. The low level of heat will make DINOC very easy to work with.
It just takes patience and practice. I see some of the prices that they offer for DINOC and I am glad that I can get the stuff for way cheaper. I can afford to practice a lot. HAHAHAHAHA
Old May 17, 2011 | 07:12 PM
Positron's Avatar
Very good info, thanks. Your price on the Di Noc is cheap! Cheaper than ebay.
Rexpeed
Evo 'For Sale' Exterior Styling
640
Jun 19, 2019 08:20 PM
Rexpeed
Evo 'For Sale' Interior Styling
678
Jun 19, 2019 08:18 PM
Superchargedk20
Oct 7, 2016 03:08 PM
15FEFTW
Jun 6, 2016 03:51 AM
4g63girl
May 22, 2015 04:39 PM
