Evo9 MR headlight issue, need assistance
Old Oct 8, 2011 | 05:19 PM
NexusEvoIX's Avatar
Hi, I have the evo9 mr with under 20k miles and my headlight just went out. I went to see what was up and I noticed that when I turn the lights on the motor that adjusts the angle will run for about 15 seconds. I found the lead that goes into the adjustment motor and when jiggled the motor will run. I jiggled the other side and that did not happen. I was wondering if anyone knew what was going on or if anyone has had the same problem that could help.
Also, I had the bumper off right before this happened. Might have knocked off a ground during reassemble? Just a thought.
thanks for all the help
Old Oct 8, 2011 | 06:29 PM
sujinX's Avatar
what is your level adjuster set at?
this happened to me after i painted my housing. i found that it kept bouncing up and down (the beam) so i just moved the headlight adjuster to 0 and it stopped. your problem might be different.
Old Oct 9, 2011 | 09:33 PM
NexusEvoIX's Avatar
I leave it set at 0. I tried all the different settings and no change.
