Turn signals dont work heeelllppp
Subscribe
Jul 21, 2013 | 12:31 PM
Hey guys well im trying to re inspect my evo 9, but for some reason my turn signals do not work, they dont even show up on the cluster, i xan hear the relay click but nthing else, everything else lights amd all work just fine plz help
If anything msg me or txt me asap plz 3025471356
Reply 0
Jul 21, 2013 | 12:49 PM
fuse forsure
Reply 0
Jul 21, 2013 | 01:07 PM
Quote: fuse forsure
I checked all my fuses in the engine bay and all where in good working order, ppl say its my etacs:/
Reply 0
Jul 21, 2013 | 03:15 PM
turn signal relay.
Reply 0
Jul 21, 2013 | 03:30 PM
Quote: turn signal relay.
Uthink? I can hear the relay tiking though! Where is the relay located at? Exactly dont want to follow a tick lol
Reply 0
Jul 21, 2013 | 04:31 PM
+1 on the relay bud.
Reply 0
Jul 22, 2013 | 10:02 AM
Turn signal light has it's own circuit from the other lights in the headlights and brakelights assembly.
The relays are located in your interior the etacs ecu is C-224 where the relays are located, not sure if you can access the relays or if they are inside the etacs ecu unit. You must investigate.
Also it could be the fuse, did you check your interior fuse box as well? It's on the left side under the steering wheel. On the diagram its labeled fuse 8 didn't check where it's located but it might be interior fuses.
http://www.ebay.com/itm/03-2003-LANC...290#vi-content
Looks like you'll have to replace the whole unit, doesn't look easily serviceable, you would need to probably do some mickey mouse soldering and breaking that thing open to fix it yourself.
Reply 0
Jul 23, 2013 | 06:00 AM
Hey guys really appreciate all the feedback and help, i cracked open the etacs and yea a circuit on the board is fried, i ordered the etacs and getting it today, i will be back to update!
Reply 0
Jul 23, 2013 | 01:22 PM
UPDATE:
Well got my etacs in the mail today, instated it amd waaahhhlllaaaaa worked!lol thnx for the help guys!
Reply 0
Jul 23, 2013 | 09:10 PM
Good to hear, now I know what to check if this happens to my car, which eventually it probably will, but I own an evo 8 kind of surprised the etacs already burnt on your evo 9.
Reply 0
Jul 24, 2013 | 04:56 AM
Yea man its weird , cracked open the old etacs and the turn signal circuit was fried, but its my fault i belive , must of fried it some how while wiring my alarm or gauges.
Got it for $55 shipped on ebay!
Stealership asked $450 lol
Reply 0
Apr 30, 2014 | 02:48 PM
Bringing this one back. My turn signals/hazards stopped working today, a very weak buzzing noise comes from the Etacs Ecu, in the same pattern as a turn signal just no actual lights/lights on dash, and my brake lights also stopped working. Prior to this my wipers started working only on Low speed setting and my fog/high beams don't work.
I have checked ALL fuses, none are blown. I have checked electrical connections at the kick panel on the drivers side and none seem to be comprised. I literally cannot figure this out, if I replace the Etacs Ecu will my brake lights and fog/high beams come back too?
Reply 0
Sep 4, 2014 | 02:49 PM
Need help
So my 05 evo mr. I am having signal troulble they don't work at all inside or outside the car when I push the stalk down or up. But when I push the hazard switch they work inside and out help please !?
Reply 0
Sep 5, 2014 | 08:56 PM
it could be different for you guys but in australia we have had a recall of some evos because of a crack in the circuit board causing the turn signals and lights not to work. https://www.recalls.gov.au/content/i...itemId/1062121
contact mitsubishi and see what they say about it
Reply 0
Subscribe
