IX MR w/factory HID - easy way to disable "auto headlight leveling"?
Old Oct 6, 2014 | 12:48 PM
Jp7's Avatar
Jp7
I'm looking for an easy (preferably reversable) way to disable the "auto leveling"feature of the factory IX MR HID headlamps.
I could not find a fuse that could be pulled but something like this would be great.
I know I could disconnect the 3 wire connector that feeds power to the motor but then I have to deal with sealing the connector from water.
Anyone know of an elegant solution to make this work?
Old Oct 6, 2014 | 01:22 PM
llDemonll's Avatar
What's wrong with the auto-leveling?
Old Oct 6, 2014 | 01:30 PM
Jp7's Avatar
Jp7
Long story short, I think the adjuster to shaft connection is stripped because my worm-gear cable was bound up and prevented the whole assembly from turning together.
I really don't see a need for the auto adjusters as I want to aim the lights the way I want to myself.
Just want to disable the system
Old Oct 6, 2014 | 03:00 PM
llDemonll's Avatar
You can just remove the cable-drives you're talking about. I did on mine so that I can adjust the low-beams at any time. I also don't care if the high beams adjust with the low beams or not. I just set the high beams where I want them and don't touch them
The auto-adjusters keep the left and right headlights at the same level and will auto-adjust (hence the name) if they are different
Old Oct 6, 2014 | 05:06 PM
Jp7's Avatar
Jp7
Cables area already removed. It bound so bad that the plastic adjuster on the low beam actually stripped a little bit on the shaft of which it seats (even with the cable totally removed)
So, even with no cable and a 5mm socket directly on the lowbeam adjuster it still only spun the adjuster without spinning the shaft that moves the projector. The inside of my adjuster is worn a little bit.
If the motors move the "drive shaft" and the 5mm knob is bound up it will tear up where they seat into the adjuster.
john blaze
Jul 31, 2016 06:56 AM
Sti THIS
Oct 17, 2010 09:27 PM
randomevo
12
Jun 26, 2009 04:56 PM
UCB
Apr 6, 2008 04:16 PM
