more headlight issues
Old Feb 21, 2016 | 06:45 PM
tbaird58's Avatar
trying to adjust my passenger side low beam....
ok so bent the metal tab back and put a screw driver in and starting slowly turning it counter clockwise with the lights off and it wasnt working, so i tried unscrewing the black cable to see if it was causing a snag and still nothing. i turned the lights on and tried it to see if the motor would try to autocorrect and it wasnt moving...is something else that could be to get them to move?
Old Feb 22, 2016 | 06:09 AM
edsct9a's Avatar
When I adjusted my HIDs I couldn't get it to move my sticking a screw driver in there, felt like I was going to strip the gear. After taking off the black cable, I pulled off the gear and found a socket that fit in there and wouldn't turn until I sprayed some electrical cleaner in the part you stick the screwdriver in. Try cleaning it first and try the screwdriver, if it doesn't work try the socket on the cable.
Old Feb 22, 2016 | 05:06 PM
tbaird58's Avatar
i tried the cable but its so chewed up from the previous owner i cant do anything with it. and you talking about the little hole where there cable connects to for the cleaner? because when i look in there i cant see any gear at all just the metal at the bottom
Old Feb 22, 2016 | 07:48 PM
edsct9a's Avatar
Where you tried sticking the screwdriver the first time right under the bracket you bent. I couldn't get anything to move until I sprayed cleaner in there.
Old Feb 22, 2016 | 09:40 PM
tbaird58's Avatar
alright i will give that go and see if that works
Old Feb 26, 2016 | 12:42 PM
Ajrst's Avatar
Need headlights
Hey guys I'm looking for a driver side Evo 8 headlight. Can any one help or knows some one selling good used ones
maknuge
AEM EMS
11
Nov 19, 2014 11:11 AM
phenem
Oct 11, 2008 08:47 PM
