Requesting help from someone with a multimeter
Old May 27, 2016 | 06:14 PM
Raptord's Avatar
Hey folks,
I'm starting a little project of getting the fog lights to have full manual control with the OEM switch, and noticed that the light inside the switch wasn't working anymore. When I disassembled the switch the little bits of wire attached to it were broken off from the bulb and practically soldered to the metal contacts. I checked what voltage was going through that current when the light was supposed to be on, and it came out to 12V.
Would someone with a multimeter (and a working fog light switch light!) mind taking their fog light switch apart to check the voltage going through that circuit when low beams are on? I have a feeling it's not supposed to be 12V...
Pic to help: the light bulb circuit is through pins 3 and 4 (circled in red), which are in the middle of the connector. The light bulb should be where my blue circle is.
Old May 28, 2016 | 09:03 PM
Raptord's Avatar
If any one ends up doing this, while you're at it, could you also check the voltage on pins 1/2 when the switch and foglights are on?
For anyone hesitating about taking their switch apart, it's easy to do and to put back together, promise!
Clipse3GT
Evo X How Tos / Installations
Feb 19, 2015 08:13 PM
neonglh
Jul 24, 2011 08:48 PM
superflyevo
For Sale - Miscellaneous Automotive
Jan 13, 2006 02:11 PM
