Wiring up 3 gauges from the center pod
Old Aug 9, 2018 | 10:53 AM
TomekEVO's Avatar
Am I able to connect the 3 wires into 1 wire butt connector and then lead just one cable from the other end to the power source. I was thinking of using a plug in fuse with the wire for the power to the gauges. I am pretty sure that using this method of putting the 3 cables into the butt connector and then leading one cable to ground will work fine but not sure if that is going to work for the power.
Old Aug 9, 2018 | 12:58 PM
llDemonll's Avatar
You'll be fine
