100w led light bulb on evo 4-6?
I installed 70W halogen low beams and 100W halogen high beams in my Evo 9 RS.
I got a kit for the high beams with a separate relay and heavier wire. Runs through its own fuse.
The low beams run on stock wiring.
No trouble with the lens or housing.
Problem with aftermarket LED's is getting the emitter in the correct position. If that is not done the focus is disturbed badly.
