Problems with Satilite
Can anyone come up with a good reason that when it gets really hot outside, my satilite reception is non-existant? once it cools down insode the car it pops back. this just started over the last couple weeks and persists only when the interior is hot. never did that before.
running a pioneer deck ( it works fine when its hot inside, because when I change mode to the regulkar antenna it works) with a sirius sat unit. any thought? :dunno: |
Mine did the same thing with my Alpine unit. The satelite tuner box was bad and it got too hot. I just replaced the unit. Also, make sure to check all your connections and make sure nothing is loose.
People have had the same complaint about the Clarion Calypso plug-and-play. Maybe a design flaw?
Where do you have the box mounted? Is it the SIR-PNR box that works with pioneer heads? You may want to try mounting it somewhere where it can get a little more air circulation. My SIR-CL3 (same thing but for Clarion) noted the need for air circulation in the manual. |
never had that once since going sat. three years ago. But I'm using Eclipse aux w/ Delphi sat tuner. Only black out is under bridges for me...
Its probably the tuner box. Sirius receivers run hot.
Where do you have the box mounted? Is it the SIR-PNR box that works with pioneer heads? You may want to try mounting it somewhere where it can get a little more air circulation. My SIR-CL3 (same thing but for Clarion) noted the need for air circulation in the manual. Its mounted on the back side of the glove box. it moves with the glove box door but, when you open the glove box you dont see it. you have to romove the glove box to get to it. needs more air hey? humph. i had no problems at all until the weather got really hot and humid over the last couple weeks. |
Just got mine installed and running last night. After about 45 minutes it gave me a "Searching for Signal" message. Drove for about 10 minutes on the open highway, never came back on. The box was on the passenger side floor. Hasn't been mounted yet, gets plenty of air there.
May have to rig up some kind of PC fan just to cool it off? hmm. Great programming. Horrible equipment.{thumbdwn} |
Originally Posted by BillAce
THat is your antenna not the receiver. Where did you mount it?
If your windows are tinted with a tint that is metalized it will mess with the reception when the antenna is mounted inside. I had mine mounted on my front dash and it would get get crappy from time to time (my windshield is fully tinted). Put it outside on my roof (not alum) and no problem. Just a thought for those that mount them inside and have bad reception. For aluminum roof get some of the 3m double sided tape and put on your roof. The tape is pretty thin, but holds real good.
Yeah I may end up going with the tape idea. I got my windows tinted with 3M satellite/nav safe film just for that purpose. It actually acted the same way before I got them tinted.
With Sirius your reception will change due to direction of travel and time of day. They use 3 moving satellites and have less ground repeaters than XM. XM has 2 stronger stationary satellites at the equator and more repeaters on the ground.
It is more important that the antenna has a clear view of the sky with Sirius. |
the antennas frequently go bad. it is the single biggest source of comebacks for us(probably 2x for 1 of all other problems combined)
what you are describing can be the tuner is getting to hot(rare, we never have that problem anymore, and we are in the arm pit of the us) but most likely your seals and body steel are flexing slightly with the temp change(or the antenna wire itself is expanding) and cutting signal off. those things are real picky. get another antenna and plug it in and put it on your roof while its doing it. if it doesnt help its a bad box |
