Evo's with big systems
I have a system in my evo and i always stayed away from getting rid of the bigger battery. What is everyone doing out there? Will i have a problem with a smaller battery? I have two Audison amps and i do have a high end sq system. I just dont want to have any problems with the system and the alarm!
Stephen |
I have a pretty big system (around 1700 watts rms) and would not consider a mini battery....ever.
you can always do what i did, i took a optima yellow top from a honda civic or miata. there slightly bigger than a mini w/o all the problems. Never had ANY problems since.{thumbup}
You can get a bigger alternator if you're wanting to run a mini battery.
Originally Posted by biggie5252
(Post 6454910)
If you plan on getting a smaller battery i would look inot rebuilding your alternator or buying a new bigger alternator. |
Originally Posted by brianeclipse98
(Post 6454052)
ive actually been planning on putting a big setup in the trunk with possibly 3x10, 2x12 or 2x15s in an extremely small aperiodic enclosure...imagine 2 15s in a 1.5 cubic foot box and it wont weigh a ton
I wouldnt consider a mini battery with more than 400 watts. Stock alternator only puts out ~100amps @ 2K RPM... and that being on a cold day.
Originally Posted by frycztech
(Post 6453265)
Stephen |
Originally Posted by HELOVESTEHBOOST
(Post 6456248)
You don't need to take one from a Honda or Miata. They sell them at Sears if you can't find a Honda or Miata with one already in it. {thumbup}
ok i didn't actually take it, i bought it:lol: |
Originally Posted by LancerEVA06
(Post 6456313)
If you have 2 Audisons you're probably pushing quite a bit... you can always get a mini battery if you're gonna run a UICP that requires the mini, and just put a 51 series yellow top in the trunk.... not like you're looking for weight savings. :lol:
(Post 6460772)
If you do this, and want them to both charge of the alternator, you will need an isolator.
(Post 6462994)
It's not really required, however it's the right way to do it. If you have identical batteries (same age, brand and use) you wont need to isolate them, but if you have 2 different batteries you'll over charge one and kill it.
im running a 600 wat amp with a small batt and no problems yet
I would seriously just consider getting an efficient amp. I've been running the same set-up for years now, and have never had a problem. Downgrading the battery while using a system just doesn't seem beneficial only even saying it.
| All times are GMT -7. The time now is 04:37 AM. |
