Upgrading factory system.
Obviously the Evo was never built for much more than performance,but I can't stand the horrible quality of the factory speakers.I'm using a Pioneer P6200BT but the quality didn't seem to get much better messing with the settings. So I'd like to upgrade the speakers in the rear and the front door speakers. I've been searching but I can't find the size of the factory speakers. I don't want the weight of a sub in the trunk,so I figured just a decent amp should help with whatever speakers I use?
Any input would be appreciated. |
Originally Posted by Dynhamik
(Post 8943264)
Any input would be appreciated. 2. Check whether the speakers are wired in phase at the deck. Edit: almost forgot - the factory speakers are oversized 6.5"; you can get adapters on ebay. |
Originally Posted by FJF
(Post 8943285)
1. Exactly, which setting are you messing with and what do you hear when you change them?
Originally Posted by I4UnderPressure
(Post 8943290)
I was searching this a bit ago. I thought ours were 6.75" and that there were some that would fit without adapters??? I hope so..:confused:
(Post 8943285)
2. Check whether the speakers are wired in phase at the deck. Edit: almost forgot - the factory speakers are oversized 6.5"; you can get adapters on ebay. I was just messing with the equalizer settings. I guess it sounds a little bit better with the presets it has,but still not so great. Thanks for the input guys. So basically I can't just find any 6.5" to replace the rears without an adapter? |
(Post 8944228)
(Post 8944252)
I hope you're not disappointed if it doesn't sound a much better with different speakers. Looking at your mod list, your car is pretty loud. I've written quite a bit about audio in our cars. You can have a look at my other posts, or at the very least add a good amplifier when you install the speakers, if you want to hear music clearly at speed.
The adapters aren't a big deal. They're inexpensive, they fit perfectly, they're easy to get, and they provide a better surface for the speaker to mount to. Good luck. Actually my car is surprisingly quiet for what it has. But even sitting at idle,the stock speakers sound like crap. Everything is balanced in the settings but it seems like I hear the rear speakers WAY more than the front door speakers. Thats probably what annoys me the most.lol |
(Post 8944334)
check your wiring on the head unit. Maybe something came loose or not connected right.
^^Ok, I will thanks.
Its the trebles that are awful. The rest might be ok (it's the case on my ralliart atleast). Most hifi will fit together with the high-pass filter (i removed the plastic of the filter for more space) if you just splice into existant cables and use the existant housing (if it's remotely the same as with mine). I just removed the old ones and taped them as they are very light. Easy mod and cheap. I suggest trying this before changing mid-low speakers as it's alot more work aswell. GL
So I decided to splurge a little on these yesterday.
http://sphotos.ak.fbcdn.net/hphotos-..._5373104_n.jpg I was trying to pick up this Polk 10" sub and box also,but they were out of stock,but said I should be pretty happy with these coaxials. Thanks again for your help guys. Hopefully these will be going in tomorrow night. I'll most likely be using an old school Alpine V12 4 channel amp. |
(Post 8953752)
(Post 8944334)
Still, its relatively loud. Especially the drone. |
