Evo 8 windows, master door lock, wipers, power mirrors do not work
My windows and most other stuff Interior wise do not work for some reason in the car. Idk what happened happened but they're just not working at all. I checked all fuses and they're all good. The wierd thing is that the passenger lock switch locks and unlocks the door perfectly fine. Any body have an idea where I could start diagnosing this.
their is fuse that sends power to all the locks and windows.. its under the hood. in a the fuse box in a yellow fuse holder check that..
Yes they are both good so thats Y I dont understand. Im scared its that Etacs unit. How can I diagnose that its bad.
try to power the windows and locks manually see if they work. and also see if u have power at the connecter for the switch and motor..
What do you mean by powering them manually?
I know this is a little old, but was this problem ever figured out. My evo has the same issue
Figured it out. Was the wires where the door opens and closes.
I have a similar problem. My driver's side door lock only locks/unlocks manually (key or by hand). The power door switch and remote won't lock/unlock the driver's side only. If I manually lock the driver's side, then all the other doors can lock with the remote or power door lock. I took off the panel and can't figure out what's going on to why it doesn't work. Anyone experiencing this and have a fix?
bump
had the same problem was the master switch got a used one from ebay problem solved
Originally Posted by kaotikkk
(Post 9792177)
Originally Posted by 10isace
(Post 9765290)
(Post 9792177)
I have the same problem I think you need to replace the the whole power door locking peice because it is all one unit. Mitsu part number is # MN159933
I hope this helps |
i know this is very old but where exactly is this wires that's being referred below? :helpme: plz
Originally Posted by white4g63
(Post 9717624)
