Evo 8 windows, master door lock, wipers, power mirrors do not work
Old Aug 20, 2011 | 04:38 PM
chrisff521's Avatar
My windows and most other stuff Interior wise do not work for some reason in the car. Idk what happened happened but they're just not working at all. I checked all fuses and they're all good. The wierd thing is that the passenger lock switch locks and unlocks the door perfectly fine. Any body have an idea where I could start diagnosing this.
Old Aug 20, 2011 | 07:15 PM
Aman's Avatar
their is fuse that sends power to all the locks and windows.. its under the hood. in a the fuse box in a yellow fuse holder check that..
Old Aug 21, 2011 | 10:21 AM
chrisff521's Avatar
Yes they are both good so thats Y I dont understand. Im scared its that Etacs unit. How can I diagnose that its bad.
Old Aug 21, 2011 | 11:14 AM
Aman's Avatar
try to power the windows and locks manually see if they work. and also see if u have power at the connecter for the switch and motor..
Old Aug 21, 2011 | 12:09 PM
chrisff521's Avatar
What do you mean by powering them manually?
Old Oct 29, 2011 | 10:18 PM
white4g63's Avatar
I know this is a little old, but was this problem ever figured out. My evo has the same issue
Old Nov 2, 2011 | 08:11 PM
white4g63's Avatar
Figured it out. Was the wires where the door opens and closes.
Old Nov 21, 2011 | 08:06 PM
10isace's Avatar
I have a similar problem. My driver's side door lock only locks/unlocks manually (key or by hand). The power door switch and remote won't lock/unlock the driver's side only. If I manually lock the driver's side, then all the other doors can lock with the remote or power door lock. I took off the panel and can't figure out what's going on to why it doesn't work. Anyone experiencing this and have a fix?
Old Nov 25, 2011 | 08:59 PM
10isace's Avatar
bump
Old Dec 2, 2011 | 05:55 PM
kaotikkk's Avatar
had the same problem was the master switch got a used one from ebay problem solved
Old Dec 3, 2011 | 02:43 PM
10isace's Avatar
Is the master switch on the driver's side door panel that is used to lock and unlock the doors and power windows? Mine works fine for everything but the driver's side lock. Was yours the same?
Old Mar 30, 2012 | 08:06 AM
DrDeC's Avatar
SOMEONE PLEASE HELP!! I have the EXACT same issue with my 8 and i don't know what to do.
Old Mar 30, 2012 | 10:26 AM
10isace's Avatar
I bought a couple of these on ebay. It didn't fix the problem. I can hear the driver's side door trying to unlock/lock, but it seems like it doesn't have enough power to get it fully unlock/locked. I can see it move a little when inside the car. So I believe it's an actuator. I took the door panel off and I don't recognize what's going on. When I get some more time I'll figure it out.
Old Jul 7, 2012 | 10:41 AM
mayday320's Avatar
I have the same problem I think you need to replace the the whole power door locking peice because it is all one unit. Mitsu part number is # MN159933
I hope this helps
Old Dec 30, 2014 | 07:23 PM
evolutong's Avatar
i know this is very old but where exactly is this wires that's being referred below? plz
