Can’t get the fuel pump to turn on :/
Hey guys , I’ve had this problem already for a couple of months after putting the car together. I can get everything to work besides the fuel pump. I bought the cable and evoscan to try and turn the fuel pump on from the program and I can’t even do that. I have ground at the fuel pump plug under the seat but no power going to it. The 2nd fuel relay clicks on when I’m cranking, I checked the fuel pump related fuses 100 times and those aren’t blown. If I put 12v and ground into the connector at the 3rd relay in the engine bay, the pump runs.
anyone have any ideas on where to check next? I checked all the connectors that connect at your feet behind the kick panel and they all have continuity through the connector they connect to |
You're in deep, rewire it.
Originally Posted by osetsky
(Post 11975925)
also , I noticed the new crank angle sensor just says zero when cranking? It doesn’t show that it’s “on” or off on evo scan and this is the new one. I got rpm readings so that must mean my crank position sensor must be good https://cimg3.ibsrv.net/gimg/www.evo...eae1bfc79.jpeg |
