Can’t get the fuel pump to turn on :/
Old Jan 28, 2024 | 09:35 AM
hrvat-9's Avatar
Hey guys , I’ve had this problem already for a couple of months after putting the car together. I can get everything to work besides the fuel pump. I bought the cable and evoscan to try and turn the fuel pump on from the program and I can’t even do that. I have ground at the fuel pump plug under the seat but no power going to it. The 2nd fuel relay clicks on when I’m cranking, I checked the fuel pump related fuses 100 times and those aren’t blown. If I put 12v and ground into the connector at the 3rd relay in the engine bay, the pump runs.
anyone have any ideas on where to check next? I checked all the connectors that connect at your feet behind the kick panel and they all have continuity through the connector they connect to
Old Jan 29, 2024 | 05:54 PM
osetsky's Avatar
You're in deep, rewire it.
Old Jan 29, 2024 | 06:42 PM
hrvat-9's Avatar
like the hardwire method? but that still taps into the power that goes to the pump right?
also , I noticed the new crank angle sensor just says zero when cranking? It doesn’t show that it’s “on” or off on evo scan and this is the new one. I got rpm readings so that must mean my crank position sensor must be good
Tyrel Bursaw
Jul 23, 2018 02:26 AM
sourtowel
Apr 22, 2013 04:24 PM
Boostfiend
Jun 21, 2011 07:33 PM
Ekoy
Dec 20, 2008 10:22 PM
ONRAILS
12
Sep 16, 2008 08:58 PM
