Dumb, Fuel Pump Question
When you guys turn your car to acc does your fuel pump prime?
seems like i remember mine doing so. But my car quit today and i'm troubleshooting and when the key is turned on the fuel pump doesn't wine at all.
So i'm thinking dead fuel pump?
yeah i already did all that.. checked fuses and what not..
i'm hoping like hell its the fuel pump. Hope my car didnt' crank walk like my buiddies whos was built by the same shop.
his car wouldn't prime when the crank angle sensor got destoryed
hmmm, mine doesn't seem to prime. Never has in accessory mode per the fuel pressure gauge. Sits on zero. When you shut the car off after it's been running with good fuel pressure, and leave the key in the accessory mode, it shows about 30#'s pressure and slowly bleeds down to zero but it takes about 15 minutes, so I know the guage is reading correctly in accessory.
Are you guys sure it primes in accessory? Mine's an 03 fwiw and doesn't prime.
where is the fuel pump relay? in the box under the dash thats labeled relay in the manual.. just relay not fuel pump relay.. a 7.5 fuse..
if so yes
if not clue me in
if so yes
if not clue me in
i think that relay is under the hood in the engine comp. and yes it should prime but the stock AND aftermarket pumps are quiet b/c they're "in tank" pumps and run quiet regardless. especially with more fuel in your tank than less.
was this issue every resolved?
i'm having a very similar issue in my turbo lancer, i remember there being a prime on the acc position and my car won't start up now, and i'm hearing nothing from the pump.
Yeah it was fixed. When i changed pumps i didn't crank the car for long enough lol! i went back out later all pissed off turned the key and the ***** fired up.
I burnt the 1st pump up with low gas.
lSimplyMel
Dec 14, 2014 04:33 PM
