primary fuel pump issue
Old Apr 18, 2015 | 05:22 PM
MP Evo's Avatar
I'm currently having an issue with the primary pump turning on when you turn the key on, but when using a scan tool I can command the pump to turn on. Has anyone come across this issue and what was the solution?
Old Apr 18, 2015 | 11:15 PM
2006GSR's Avatar
I'm pretty sure the pump kicks on when you start to crank the engine over. I know on my 9 that's how it is.
Old Apr 19, 2015 | 05:11 AM
MP Evo's Avatar
Well when you turn the key on the one position you will hear your lift pump priming your system, but if I bypass the relay and jump it the lift pump runs so I'm leading to that the ecu isn't grounding the relay on switched on.
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
