Vibrations post engine maintenance!
Old Apr 16, 2015 | 04:23 AM
foxbat's Avatar
The car is a mostly stock Evo 7 & was perfectly fine.
I performed the following:
-Removed the head & had it ported & reinstalled again.
-Changed the timing belt with a new oem belt
-Changed the balance shaft belt with a new oem belt
Now, the engine has moderate vibrations after performing the above steps, whether the gear is engaged or in neutral!
Any suggestions?
Old Apr 16, 2015 | 04:26 AM
kikiturbo's Avatar
balance shafts are probably out of phase..
Old Apr 16, 2015 | 04:39 AM
foxbat's Avatar
Can you elobrate further? And how to remedy it?
Old Apr 16, 2015 | 04:47 AM
lostsoulsevo's Avatar
A lot of people forget to rotate the oil pump gear 180....only if it needs it. When you turn the gear and release it....the arrow should fall back in place with the notch on the case.
Old Apr 16, 2015 | 05:09 AM
foxbat's Avatar
Yes, sure, I've done that.
Old Apr 16, 2015 | 07:49 AM
Mecheng1993's Avatar
Could even be something as trivial as a boost leak causing an erratic idle. You didn't give us very much information.
Old Apr 16, 2015 | 08:48 AM
hiboost2.0's Avatar
Does it vibrate at idle? Or when revving the engine up
Old Apr 16, 2015 | 08:55 AM
wreckleford's Avatar
Timing out by a tooth?
Old Apr 16, 2015 | 09:59 AM
The timin belt could be to tight. That has happened to me. Had to re due the tensioner
Old Apr 16, 2015 | 03:00 PM
LetsGetThisDone's Avatar
Good bet the balance shafts got timed wrong.
Old Apr 19, 2015 | 02:16 AM
foxbat's Avatar
Upon revving, it's maximized at around 4000 whether in gear or neutral
No boost leaks & I have checked the timing belt & it seems fine, not too tight!
I'm positive that balance shafts setup is fine but I currently have no other option but to recheck them again.
Old Apr 19, 2015 | 05:53 AM
Like I said before, your belt is probably to tight if you know for a fact the oil pump gear is correct
craigybaby37
Oct 10, 2011 12:29 PM
aftershock141
Sep 30, 2011 08:46 PM
Psycho09RA
Jan 18, 2011 08:49 AM
therunningskier
Mar 11, 2010 06:32 AM
ODUB
Jan 2, 2008 10:17 PM
