very loud noises/vibrations coming from engine bay after service work
Old Jan 1, 2008 | 01:04 AM
ODUB's Avatar
okay, i got an Exedy stage 1 clutch, timing belt, balance shaft belt, and alternator belt put in yesterday. i haven't really taken the car over 3-4k because i'm breaking in the clutch so i didn't notice any weird noises. well earlier today i took it up higher and at about 4.5k it makes a loud rattling noise, and there's a lot of vibration coming from the front of the car and transmitting through the shifter, and all 3 pedals. it continues making the noise until the rpms drop below 4k or so. anything higher than 4.5k and the noise is very noticeable, and not one of the normal engine noises. any ideas what this could be? i looked in the engine bay while having the engine revved to see if i could see anything touching, moving, banging, or anything that could cause it, but everything looks normal.
Old Jan 1, 2008 | 05:47 AM
scottatyamaha's Avatar
When they installed your timing belt one of the balance shafts went out of phase causing the car to vibrate like that. It could be the balance shaft on the oil pump or the other seperate one. Take it back and tell them to do it right.
Old Jan 1, 2008 | 09:16 AM
KevinD's Avatar
its the balance shaft. give me a call, i'll get it fixed. i thought we revved it up far enough to notice that. the gear must have spun on me while doing it.
Old Jan 1, 2008 | 09:51 AM
gsrboi80's Avatar
Definately the balance shaft 180 out. Common mistake while doing a timing belt job. No biggie they'll fix it up for you
Old Jan 1, 2008 | 12:25 PM
ODUB's Avatar
that was the first thing i said too...just don't know how to fix it lol glad that's all it is.
Old Jan 2, 2008 | 09:46 PM
ODUB's Avatar
just wanted to say thanks Kevin for getting everything fixed right away for me. i really appreciate it. the car and the clutch both feel great. i did however play with the clutch more today to get a feel for the engagement point, and it is toward the top...higher than stock. pedal adjustment should fix that huh? i'll probably take care of that sometime tomorrow...in the garage...with the space heater running haha
Old Jan 2, 2008 | 10:17 PM
evovin's Avatar
Balance shaft! Based on all what you said
I had the same problem before when AL(dynoflash) tuned me. AL even said he is 99.9% that it was my balance shaft thats making the vibrtion! Let them adjust it.
silver_evo
28
Aug 28, 2019 06:53 AM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
WickedOne
May 11, 2011 10:53 AM
eag36
Apr 17, 2007 05:29 AM
smokedmustang
23
May 9, 2006 09:40 AM
