High boost engine compartment vibrations?
Old Mar 11, 2010 | 04:13 AM
therunningskier's Avatar
Ok I'm really hoping this isn't bad....
My car makes a vibration, somewhat similiar to the feel of a clutch that is slipping when the car is under power and over half boost. It doesn't vibrate at high rpms and low boost, or basically any other situation other than when the engine and turbo are working hard and creating more than about 60-75% power.
I'm about 98% it's not the clutch (I could be wrong i guess... it's done this for awhile and babying the clutch I've had no change in engagement for 10k) But from listening to the car it sounds like its coming from the right side of the engine compartment (......) like a hose of some sort is vibrating against the engine block.
Can that be right?
If it is right, is it merely an annoyance?
What can you do to make it go away?
Old Mar 11, 2010 | 04:19 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
You do know your in the wrong section right?
Old Mar 11, 2010 | 04:45 AM
evolution5690's Avatar
did you replace your clutch?
Old Mar 11, 2010 | 05:07 AM
Wrong section? I figured boost/turbo/potential drivetrain issues would go in the engine/turbo/drivetrain section?
Is this not that section?
And yes it does have a ACT clutch and prolite flywheel.
Old Mar 11, 2010 | 05:22 AM
tonyboy's Avatar
^^ maybe because he thought that your car is a "06 Evo IX SE" and this post/thread that you did is in the "Evo X Section"..so in any case, what car is this? check your engine mounts..it could be annoyance of some sort..but we can't really tell..
Old Mar 11, 2010 | 06:32 AM
ah touche. I'm an idiot.
Dapper Dan
Oct 17, 2017 07:26 AM
insafa
Sep 15, 2014 09:58 AM
Jesperswe
Aug 15, 2011 01:03 PM
fanbelted
Jul 3, 2009 08:23 AM
sdfontanini
Jan 29, 2008 03:34 PM
