HKS RS vs. Stock Airbox & More <My Observations>
Originally Posted by silvrevo
Ok, now go see what Al , dynoflash has to say about the HKS RS intake. He loves it and gets the most hp out of this unit.
Al happens to have the RS figured out pretty well because of all he has dealt with.
It affects the MAF readings, but fortunately it does it consistently from car to car.
Here's my short story for an opposite perspective.
I have minor mods:
HKS RS Intake
3" Turboback
MBC @ 19psi
TurboTrix ECU Flash
I made 307 AWHP on a low reading Mustang Dyno this weekend. A Dynojet would have been around 320-325. Basically, I am making (XEDE) cammed car power with no cams. For reference, a UTEC cammed EVO with my bolt ons dynoed 319 AWHP this weekend also. Dynojet on that is, what, 350 AWHP?
I outrun (in fifth gear pulls - no shifting or driver error) EVOs with cams, turbobacks, etc, WITH XEDE tuned by Shiv himself. Two to be exact.
The HKS RS Intake DOES make power over the stock airbox. But if you can't tune for it then I guess it wouldn't. I have 1K dollars in my car and I have outrun 2 Vishnu cars (with cams) and outdynoed 1 Vishnu car (no cams).
So that kind of shapes my opinion of the Vishnu program especially considering these guys have at LEAST $2500 in their cars to my 1K.
Regarding the intake, before either of us had tuning, my friend and I had the EXACT same mods except he had the HKS RS. We were indeed dead even through all of fifth gear until above 5500 RPMs. Then he started to pull on me. This can only be attributed to the intake.
Just my .02.
I have minor mods:
HKS RS Intake
3" Turboback
MBC @ 19psi
TurboTrix ECU Flash
Just my .02.
I'm so confused now
. I was gonna install my RS intake soon, now I'm not sure I want to. I don't live anywhere near a tuner, or a place with an AWD dyno. So, those factors make me want to install it even less after reading this thread....I won't be able to have a "master" tuner around to tune it properly. So, chances are, will it just mess up my car if I install it myself without having it tuned?
It's brand new in the box still. I may want to sell it after I think about it some more and research it some more.....
. I was gonna install my RS intake soon, now I'm not sure I want to. I don't live anywhere near a tuner, or a place with an AWD dyno. So, those factors make me want to install it even less after reading this thread....I won't be able to have a "master" tuner around to tune it properly. So, chances are, will it just mess up my car if I install it myself without having it tuned?It's brand new in the box still. I may want to sell it after I think about it some more and research it some more.....
Originally Posted by ArchieBabes
Can you use the HKS MAF Pipe in conjuction with the stock airbox?
Originally Posted by TheGVR4kid
What about just using a hardpipe post-MAS and keeping the OE airbox?
Originally Posted by NYREDEVO
Hmmmm....thats really interesting, so the safest thing might be just to add a drop in filter to the stock intake setup? Or maybe modifying the intake box itself to allow it to fit over an aftermarket intake? (similar air flow patern...just more airflow)
As far as putting the stock airbox over an aftermarket intake? That won't really do much for you I think... A drop in would accomplish the same thing and your box will still cancel out the sound either way.
Originally Posted by SuperHatch
In any event, this post is in no way trying to say that one tuners philosophies on tuning are better than any others...
- Steve
I have minor mods:
HKS RS Intake
3" Turboback
MBC @ 19psi
TurboTrix ECU Flash
Just my .02.
I have minor mods:
HKS RS Intake
3" Turboback
MBC @ 19psi
TurboTrix ECU Flash
Just my .02.
Lets keep this thread on topic please. Alot of info here and we dont want it to be shut
The HKS hard pipe doesn't fit with the stock airbox, I tried. Besides that, I think the transition from the MAFS diameter to the larger HKS pipe diameter could cause issues as well. It will cause flow separation at the walls and turbulance, however it will be post MAFS so it probably won't effect it.- Steve
My post is PERFECTLY on topic and addresses each issue with facts. All you weiners need to stop looking for debated hidden in normal posts and accept the facts even if they don't say exactly what you want them to.
What should I have done to make you guys happy? Left out who tuned my ECU? Well, that is ommission from the correct story or body of facts. I'm not going to do that. TT flashed my ECU. That's all I said. I never said they were better. What are you guys talking about? WTF, man!!!!
This thread is about an aftermarket intake making HP or not
Can that HKS intake flow more air than the stock airbox? I hope so considering the filter type, pipe size, etc. If you can flow more air can you make more power? Yes, I would again think so. So can the HKS intake make more power? If your car is demanding more flow than the stock airbox can provide, yes, I think it would. Do I think it's a good idea to run that intake on an untuned car? No, I don't simply because of the A/F readings. That's my opinion, call me stupid if you want.
- Steve
thanks for the info!! but your opinion is base on one tuner ability to tune, as some one has stated Al has tune the same intake and has had excellent success with it. Is that saying Al is a better tuner , no! but it does say that he can tune a car with an intake and keep a solid Air/fuel with no problems.
Aftermarket intakes have been an issue for peeps running Xede or Xflash from shiv, while there are other tuners like Buschur that are running a stage IV and making solild power with no problems what so ever. Or tuners like WORKS that have tune cars with APS CAI and have had success maintaining a nice 11.1 air/fuel with no problems.
Hey ! even Brainstorm has tune cars with the APS kit . which envolves CAI, Turbo back, Test pipe and APS ecu piggy back and have made near 300whp (AWD dyno jet) and had no problems with air/fuel.
Its nice information what you are posting but just like i said before because one tuner either choose it not to tune for intakes or well lets leave it at that. doesn't mean that the design behind an after market intake is not worth it or can not make more power then the stock box while running MAF.
What are you guys talking about?!?!?!? This thread is about an aftermarket intake making HP or not. And since the involved tuner is Vishnu, it is also about whether of not he tunes properly for it, how much his opinion does or should matter, and what ways he makes power (with the stock airbox).
Stop freaking out
, No one said anything about how much you $ spent or they spent. you keep saying 1K mode vs $2.5K
. The guy who started this thread is giving us great info about our cars and how they work, not on how much you spent or he did
. if you read his post you will know that he is taking about A/F..
Superhatch, the poster right above is giving you the reason I included the info I did. It's based on ONE tuner's ability to tune. As far as erratic readings, I am not having this problem. My car is smooth and the AF ratios and other maps are not affected. I personally think that you are dealing with the wrong tuner in order to get a valid test/result/tune with an aftermarket intake. The point of MY post was to show that it is CHEAP and EASY to make power when you ditch the stock airbox with no adverse effects. The point of me including my defeats of Vishnu cars was to say that just because he has a big name, doesn't mean he always knows best. Why don't you accept other opinions instead of trusting just one dude? That's always a quick way to find yourself behind the curve. The simple fact is that other tuners make very nice and reliable gains with an intake and Shiv does not. Sometimes when it seems like everyone else is wrong, it turns out you're the one who is wrong.
edit: ok 2 posts above.
Stop freaking out
. if you read his post you will know that he is taking about A/F..every fact I posted has a purpose. if you can't understand it and don't want to, then I really don't care. if you can't understand it and want to, let me know.
