HKS RS vs. Stock Airbox & More <My Observations>
Originally Posted by Eric Lyublinsky
But how does it do that?? Does it have fins in it?? I guess I need to studdy one in more detail.
Chris
Originally Posted by marksae
I see your point. It would be pretty silly to have a big intercooler w/ poor end tank designs if only 50% of it was being used effectively.
Packaging constraints and ease of manufacturability are usually what determines their designs. I'd be interested to see how different end tank designs affect flow distribution across an intercooler. I've always liked the intercoolers that use cast end tanks as the transitions which would probably give better distribution.
The only nice thing about cast parts is that they are always the same with almost no varince in production. But I can't see it having better distibution of air over any other method of production if the design is the same with the same flow paterns of the cast unit. Please enlighten me if I'm missing somthing?
Cast end thanks have lots of benifits, IE no varince in production, Smooth curves, and packaging. IMHO
I don't think you wrong I just don't see the temps having a big enough diffrence between a open eliment and a CAI to affect the IC ablity to cool the air unless the IC is already at it max effencey.
What do you think?
What do you think?
But as said above a true CAI could make a difference being outside of the engine bay and also being in the direct air path of oncoming air.
Chris
Originally Posted by Terry S
Well if the CAI is pulling in ambient temp and the open element is pulling in 30 degrees over ambient temp, then the IC would have to cool down the extra 30 over what the CAI would be pulling in..
Endtanks IMO are the biggest part of a IC. The goal is to get the air in the middle of the IC and of course a wide enought area to not heat soak one spot of the IC. Best way to do this is with little tiny fins each with different angles to flow the air evenly across the IC. I have seen a cast IC endtank somewhere with this design.
This all brings us to the question of how beneficial a Water to Air setup would be? Sure you are able to lower temps below ambient temp but i could also seeing it being a problem at open throttle for long periods of time becouse it would not be able to cool the air fast enough before it hits the engine. Hmm how about a FMIC that is Water to Air. Anybody know where i can get one of those?
Chris
Chris
Here's what I'm thinking.
Get an HKS RS MAF tube and instead of putting on the HKS filter, put on the APS CAI. This way, flow would be smooth like the stock box, cooler than the stock box, and high flow like the HKS/APS.
The only reason I haven't done this is because I am worried about the adverse effects of such a long intake. Are there any? Are the benefits of a smooth, cool flow greater than the adverse effects of a long intake tube? I mean, it's already really freakin long, being a turbo. What do you think?
Originally Posted by 2k4EvoVIII
So your telling me you dont think that the temp of the air entering the turbo matter by the time it hits the engine becouse the inercooler will always bring those temps to the same temps entering the engine as long as the temps outside stayed the same? How is that possible?
Say that the temps entering the IC are 100 degrees and going into the engine at 50 degrees. Now lets say the temps entering the IC are 150 and going into the engine at 50 degrees the IC would have to be cooling 50 degrees more then if it would have to cool the 100 degree temps in the same amount of time. How is that possible? Even if the IC were able to cool the air more then those temps would drop on both sides of the board giving you the 50 degree difference nomatter how you look at it. Maybe im wrong who know but that is just my 0.02
Chris
Chris
Temp is 80 outside and the air that is going into the intake is 80 right? The turbo will heat that air no matter what to some point. Now lets say the temp outside is 100 and the air is going inside is 100 the turbo will still heat that air to about the same temp regardless of the 20F difference. My point here is what makes the most difference is the IC and how cold the air that is hitting it in the front. Of course you will loose power on 100F day but that does not mean you are loosing it because the air is going in the filter is hot, it means that the IC cant do a better job because the air that is cooling it is not cold enough or not = to 80F. Turbo cars get so hot to the point (1500F) that cold air intake or short ram won’t make a huge difference if any. The difference you see is because the IC is in a hotter environment all together. I hope you can see my point here because I am not sure if I did a good job explaining it.
Chris
Chris
Chris I think PWR makes one that's water to air. But to complecated for me man. I like it simple.
but that might not be the case. Because when the turbo compresses the air that 30f might not really affect the air temp going into the IC. But again I would agree having colder air going into the turbo would be best instead of hotter air but does it make a diffrence on a turbocharged car??
I think you should sell your intake and buy a 10.8 exhaust housing and use your stock box because that will make more power bang for the buck
I lost my internet access for a bit, got it back, and wow a lot of stuff to catch up on here...
PVD04 and I are definately seeing eye-to-eye on the flow dynamics happeing inside the MAFS sensor, intake, etc.
As far as the Intake temp not making a difference, it does, period. Heat transfer proves that fact. If your intake temp is 100 degrees, and heat added by the turbo is a fixed amount, lets say the turbo itself is at 300 degrees and the heat added by compressing the gas is responsible for another 100 degrees of temperature increase. The pressure driven temp increase will be the same regardles of intake temp.... 100 degree intake temp goes to 200 from compression, 50 degree goes to 150, etc. (no I know it's not that direct, but it's damn close) The fact that cool air is traveling over the hot surface of the turbo will also add heat. This heat transfer is driven by a number of things, one of which is the temperature differential. The farther the temps are apart, the faster the heat will transfer. So say your intake temp is 50 degrees and the turbo is 300, it will heat more than if your intake temp was 100 degrees and the turbo was 300. Regardless the end temp of the 50 degree intake charge will be lower than the end temp of the 100 degree intake charge, guaranteed.
Can we let the IC topic be for a bit, or start another thread about it?
"holy post"
(sorry, that's funny)
I am willing to bet that the maximum flowrate meterable by the MAFS is not even remotely approached at stock boost levels. If the engine is running the same boost pressure, the flow rate should be the same, it won't be since the open element filter can flow more air, but I guarantee you it's not much higher than the stock flowrate. It takes a certain amount of air to make a certain manifold pressure.
If the volume of air was too great for the MAF to read it would be pinned at a single max voltage, it wouldn't oscillate at all, because it would be maxed out. That leads reason to say that, no, the aftermarket intake does not outflow the MAFS, but the oscillating signal is generated from an irregularity in flow.
It takes more than 1" of honeycomb to straighten out a flow moving at the velocity the intake air is moving at. Like PVD04 said, it's fluid dynamics, I can tell you who published my textbook and you can try to teach yourself, or you can take my word for it since I have a degree and aced the class (I know you won't)
Yes and No, if you reread my post that you quoted, you would understand my reasoning.
I can't even make this comparison, two different cars, two different tuners, maybe he had bad gas causing knock that made the graph rough, maybe he had fouled plugs that randomly misfired making a roung graph, there's no way to know, which is why we've all said you can't compare two different cars in two different places. Which is also why I believe my argument is very well founded, it is two different intakes dynoed on the same car, with the same gas, at the same place, the same day, 15 min apart (the time it took to swap intakes), on the same tune! One is smooth, one isn't, the intake is only thing that changed, so the intake is to blame for the erratic A/F graph.
I don't think it should either! But once again, my post about compensating for an oscillation, and what happens if that oscillation shifts explains why compensating for it with a tune could be a bad idea.
I havn't said "no you're wrong" without a reason yet.
- Steve
Anyways, I want to pose this question since it was not addressed in the initial "holy post" of this thread. What is the maximum voltage readable by our MAFs and what does it read with the stock airbox and what does it read with an aftermarket intake?
(sorry, that's funny)I am willing to bet that the maximum flowrate meterable by the MAFS is not even remotely approached at stock boost levels. If the engine is running the same boost pressure, the flow rate should be the same, it won't be since the open element filter can flow more air, but I guarantee you it's not much higher than the stock flowrate. It takes a certain amount of air to make a certain manifold pressure.
What I am asking is, "Is the apparent result of an unstable reading caused by a disruptive flow over the sensor or a smooth flowing but a volume so high that the MAF cannot interpret it?"
Can any of you explain how air flows unevenly over the sensor when it is behind a straightener that seems to be an inch long? Should the honeycomb in the MAF not take care of the uneven flow?
Another point I would like to make further justifying that this is a tune issue (ie stock tune can't interpret this but an aftermarket tune can thus the problem lies in the tune program) is that:
1) The issue is correctable with a good tune
2) Not only did the aforementioned Evolution owner with a Dynoflash dyno 30 HP less than me with the same bolt ons, his graph is quite jagged and unsmooth compared to mine (TurboTrix flash - only difference). So is this also attributable to the intake? Or the tune? It has to be the tune since we both have the same intake.
Can anyone tell me why a tune (factory program) that is not designed to read anything but a stock intake SHOULD read an aftermarket intake smoothly? I don't think it should and I still don't think the problem lies in the intake. My argument is just as solid as any presented as of yet.
This post is not off topic just because it offers a different perspective so don't use that as an argument and please just don't say, No, you're wrong and not give a reason. That only strenghtens my argument. Bring something to the table.
- Steve
Originally Posted by Az3ar
it wont make a difference on turbo cars except if you are living in saudi arabia in the middle of no where temps are well over 120F. the turbo is already so hot that 20F difference wont make you loose HP.. you will be loosing HP because your IC is in a hoter weather all together.
Ok I think we all agree colder air is always better
I see your point Myher and yes the biggest thing that will effect it is the heat that is outside. But once agian like you say the turbo is going to heat the air up anyway but why heat it up more then it has to. Either way the air that is going to enter the engine will be that much hotter if the air is getting sucked in that much hotter. You cant tell me that the turbo is going to heat all the air nomatter what to the same degree and then inject it into the IC. That is impossible.
Basically i think everybody has made there point about the temp of the air entering the engine. Yes it is better to have as cold of air enter the turbo as possible. Is it that beneficial on a turbo car? Probably not becouse of the heat the turbo will produce anyways that you wont see that much of a difference but the difference is there!!!
Chris
Chris
Chris, I Think you are right. However, lets think about it this way ( real life way).
Chris
Chris
Eric and Chris,
You guys know well that turbos are made and designed to withstand very very high temps well over 1000F. Lets say the air that is going in is 70F and in another example its 90F that 20F difference, that is nothing to make a difference because its not going to lower your turbo temp from 1000F to 980F right? Except if you live in Canada and the weather was 10F below even if that, that will help for few until our turbos are sooo hot again. On turbo cars we should focus on cooling the air after the turbo not before. Using bigger IC and WIK will do it.
