arp bolts and studs worth upgrading?
Just use the FSM torque order... there are a couple of the OE washers that seem to be a pita at first, as they are slightly under the edges of the valve springs. Here is where a magnet/long needle nose pliers is/are very handy... makes the job a cinch.
If you do have higher mileage... or have altered the "tune" of the car, I would be inclined to first run a compression check to make sure everything is in good order prior to the "one at a time method".
DIDYSIS
Oct 19, 2008 11:19 AM
rt turbo
11
Jul 15, 2003 02:19 PM
