boost problems
Old Oct 3, 2004 | 04:46 AM
fahdc's Avatar
boost problems
Hi guys i have just installed a greddy E01 and i am problems going past 12 psi....no matter what i do my boost does not seem to cross 12 psi i have a evo 8 so please your help is greatly appriciated...
regards
fahd
Old Oct 3, 2004 | 09:33 AM
PVD04's Avatar
It sounds like your wastegate isn't being held closed by the boost controller. I would check your vaccuum lines going from the valve unit to the wastegate and pressure source. Also, make sure that your wires running to the valve unit are not cut anywhere.
Old Oct 3, 2004 | 10:17 AM
EVODreams's Avatar
Lightbulb vacum line size
Make sure you have the correct vaccuum line size going to and from the boost controller
