AVC-R Problem
Old Oct 3, 2004 | 10:15 AM
Karash's Avatar
AVC-R Problem
Well a few of us decided on trying to install this boost controller. We thought we got all the vac lines right, and wires. We hooked up the "purple" wire to the Tach signal instead of injector 1. However, when I try to set and test it...the car will not go over .9 or 1.0 bar. I unplugged the AVC-R from the harness and got the same results, leading me to believe we have a hose problem. Any ideas on this?
Old Oct 3, 2004 | 04:35 PM
Karash's Avatar
Nevermind guys, we finally figured it out. Had the hoses backwards on the 'noid. All good now...boosting 1.4 bar solid to redline.
Old Oct 3, 2004 | 05:00 PM
EVOTEXAS's Avatar
Sounds like B.G.A. must have hooked it up the first time!
Old Oct 3, 2004 | 05:09 PM
Karash's Avatar
Haha, well have to blame me on this one
I love the unit so far, once hooked up properly (ahem), it has a ton of features. 2 boost settings, gear learning, auto learn mode, peak hold settings, even a scramble option. I need to buy me a scramble switch and mount it somewhere.
Old Oct 10, 2004 | 12:46 AM
BushBurninEvo's Avatar
If you don't mind posting your settings that would be great.
