little help please
Old Oct 15, 2004 | 02:32 PM
ctevo's Avatar
Unhappy little help please
I just installed the BR minibattery kit. I had to take my HKS RS intake off and then reposition the pipe for it so that the mushroom filter would fit with the mini battery. Now for whut ever reason all I get is fluttering from my GReddy type-S BOV. I had never had this problem before, it was always a crisp clean chirp or whooosh at higher boost. Now no matter how high or low the boost is I get a flutter everyime I let off the gas. I also can't seem to be able to boost over 16 or so psi when before I was running ~21. I have tried adjusting the vavle and no matter how tight or loose I have it It still flutters. The only effect I've had on it is I have to have it adjusted almost all the way in )only like 3 threads left showing) to even get it to hold 16psi where as before it was holding 21+ with ~8 threads showing. I checked all the clamps and pipeing and there doesn't appear to be a leak anywhere so I'm wondering if anyone knows whut the hell this is?!?!? The battery kit repositioned the intake about an inch or two but everything still is lined up from whut I can tell and not even my intake quite sounds the same anymore.
Any help would be appreciated
