Walboro Fuel Pump
Old Oct 19, 2004 | 06:22 AM
YEVOVIII's Avatar
Walboro Fuel Pump
I bought the pump for LANCERSHOP.COM and all I got was the pump. Yes I should have read the fine print. Will I be fine? Can't my new pump be installed using the existing harware on the stock pump?
Thanks
Tony
Old Oct 19, 2004 | 06:26 AM
sleet's Avatar
You need nothing more than the pump to install it. You simply take out the stock pump housing, remove stock pump, remove stock filter/grommet, install onto new pump, put pump into housing, housing back into car. It took me about 20-25 minutes total. If you need a more into depth write-up, I suggest you go here:
http://www.evomoto.com/tech_info.php...3_13&tech_id=9
