Heat Range 9. Good or bad?
Old Oct 23, 2004 | 06:34 PM
k270kmh's Avatar
Unhappy Heat Range 9. Good or bad?
Guys, I bought a Ralliart ECU and it gives an agressive spark timming. Ralliart doesn't give any inofrmation about which mods you have to put together with the new ECU. So I went to HKS Kansai web site and saw a performance ECU similar to Ralliart, but they recommend to use some performance parts like the HKS S45G spark plug that is Heat range 9!!!
Someone here tried the Heat Range 9 spark plug?
What are the benefits and problems running with a cooler spark plug?
In my case with a performance ECU... Is necessary to go with a heat Range 9?
HKS web site: http://www.kansaiss.co.jp/parts/kcm10.htm
Old Oct 24, 2004 | 10:43 AM
cleanevo's Avatar
Unless you have over 900 HP that sparkplug is so cold that it wouldnt even fire , That porclein would be so for in the plug that you coundnt see it , First you have to make the power than contol it with a the heat range of a spark plug.
Old Oct 24, 2004 | 12:33 PM
k270kmh's Avatar
Do you know why HKS Kansai recommend HKS S45G?
Thank you for your answer!
Old Oct 24, 2004 | 01:46 PM
Dom's Avatar
Dom
It's always better to run colder plugs to prevent knocking.
In fact the colder plugs retard your timing slightly.
9 is a common plug for RX-7s but for a street driven Evo I wouldn't go
colder than 8.
And yes, you can run the Ecu even with warmer plugs but they reccommed
the colder plugs for safety issues.
My FD runs (and starts) fine with HR9 plugs
Old Oct 24, 2004 | 02:47 PM
k270kmh's Avatar
Thank you Dom!
georg1970
50
Dec 20, 2021 03:19 AM
foxbat
Jul 26, 2016 01:10 PM
Done
210
Apr 4, 2015 10:47 PM
k270kmh
14
Jan 10, 2007 02:45 PM
k270kmh
Dec 18, 2004 11:48 AM
