walboro fuel pump noise?
Old Oct 24, 2004 | 04:48 PM
BushBurninEvo's Avatar
Mines making a whiny noise...is that normal? I thought it was suppose to be quiet?
Old Oct 24, 2004 | 04:51 PM
SurfguruJon311's Avatar
I cant hear mine at all!
Old Oct 24, 2004 | 05:01 PM
pgmike's Avatar
i can hear mine, its noticable, but you get used to it. i have the rear seat off right now and its very loud, i like the soudn tho.
Old Oct 24, 2004 | 09:03 PM
Invoice EVO's Avatar
Veteran: Air Force
I've got the noise, no biggy.
Old Oct 24, 2004 | 09:07 PM
evo81's Avatar
only in the heat,and long trips you'll hear the pump.
Old Oct 24, 2004 | 09:41 PM
DocMortal's Avatar
I hear it cause I know what sound to hear for...
If I didnt probably wouldnt notice...
No Worries
Old Oct 25, 2004 | 01:34 AM
GREDDY's Avatar
Just installed mine and it's quite as hell. Can't even here it with the black metal cover off.
Old Oct 25, 2004 | 05:40 AM
sleet's Avatar
Hmm....is it possible to hear it from outside the car? I recently drove to tampa and back, i've never really noticed it but I keep hearing like a whinning noise, is that how it sounds?
Old Oct 25, 2004 | 05:48 AM
KINGEVO7's Avatar
Yes they are supposed to sound loud and whiney,at least the bigger ones.
Old Oct 25, 2004 | 07:00 AM
propellerhead's Avatar
Repeat after me:
"WALBRO"
"WALBRO"
"WALBRO"
I have a 255lph. It doesn't make any noticable noise unless the fuel level is low.
Old Oct 25, 2004 | 07:28 AM
DynoFlash's Avatar
Interestingly - in the past two cases of a slight noise from a Walbro pump , I decided to remove the pumps for inpsection and in BOTH cases I discovered the customers had NOT properly installed the pump and the discharge from the pump was not fully seated into the rubber bushing in the pump housing
When the seal is not fully made between the pump discharge and rubber bushing it is possible for fuel to leak into the tank which causes the pump to run faster at idel - thus making more noise
If it bothers you - just take it out and see that the while plastic spacer is flush up against the pump and housing and the pump discharge is fully insertyed into the rubber bushing
Old Oct 25, 2004 | 09:02 AM
SinCityEvo's Avatar
Me and Bishiboy installed mine and made sure it was seated properly and everything fine. Mine was silent for a while and once the weather got hot and the car was flogged good, the pump was whining loud. Then when you let the car cool down a few hours, the pump was silent again until you drove the hell out of it again.
I have not heard my pump in a month or so now that the weather is much cooler, regardless of driving style. It's wierd.
Don't mind the sound as long as the pump does not fail over time. I question the reliability versus the OEM Denzo.
Old Oct 25, 2004 | 09:10 AM
KZEVO's Avatar
Thanks for the info. Mine whines all the time to the extent that if u don't have the radio on it's way loud. I got used to it, but i guess it could be that it's not installed properly. I'll check later on. thanks again
Old Oct 25, 2004 | 09:14 AM
EVOTEXAS's Avatar
You can only hear mine in the dead summer heat.
Old Oct 25, 2004 | 09:16 AM
sleet's Avatar
Yeah mines really loud and I made sure it was in there all the way. I think it was just whinning real loud because of the drive home, it was pretty intense
