Does the hose going to the wastegate connect to the front or rear soledoid nipple?
When you look down at the wastegate solenoid there are two places for the line to come off. One is towards the front of the car, one towards the rear. They both stick out parallel to each other pointing towards the passenger side. Which one goes to the intake tube, and which one goes to the wastegate plumbing? Does it even matter? I may have hooked them up backwards, if so would this throw a 0243.....wastegate solenoid malfunction? It is still plugged in as the Xede uses it to control boost, and it seems to be working, but it keeps on throwing the code. This is a recent problem that just cropped up after I rebuilt the engine which was out of the car for 5 months. I slept a few times sence then so I may have them reversed. I think that I have the line to thewastegate on the forward nipple and the intake tube line on the rearmost nipple. Thanks
