Can you drive with untuned cams?
I am planning on installing some HKS cams (not sure which kind yet) and a UTEC. My problem is I may want to get the cams installed first, and then make the drive to get the UTEC tuned. Is it safe/possible to drive with the cams untuned for a few hundred miles to get the UTEC tuned? Would it be different for 264/264 or 272/272? What about 264/272? I did a search and it seems like it is definitely possible. I just need to know if it is safe. Thanks for your help.
Yes, it will be fine. I wouldn't try pushing it super hard till after the tune, but the car will run fine. With 272/272 you might get some stalls, since the idle will be off. Otherwize you'll be OK.
Good luck!
Good luck!
Good luck!
Good luck!
Thanks. That's what I wanted to hear
You will be fine, your idle will be rough and there may be some stalls, but other than that you will be ok. I drove mine for a while untuned and didn't really feel a huge difference. Once you get tuned the topend greatly improves
