>>>High compression engine advice<<<
Old Dec 16, 2001 | 03:02 PM
Blade's Avatar
Check out Manuel GO's EVO - he used JE pistons with something like a 9.8:1 compression ratio, and 1.4 bar boost - he gets circa 500bhp with a bigger turbo.
Higher compression is equivalent to more boost at the end of the day, so I am surprised they allow higher compression but not more boost! Guess they are forcing you to got the (expensive) mechanical way, and not use electronic trickery. I think if you go over 8.5:1 you will need 100 octane fuel for sure.
Old Dec 18, 2001 | 02:41 PM
evoVI_PR's Avatar
I think that is exactly what the want. To force us to spend more money and have more trouble to find a correct setup. The octane is no problem since I already run on race gas, 114 octane approx. As of right now I am leaning towards JE forged pistons at least 9.8-1 compression, and crower rods. Retaining stock ECU for now, and 1.2 bar.
Julian
Old Dec 19, 2001 | 02:34 AM
Michaelk's Avatar
The parts sound good for you, especially as they are US makers. But you might find that you'll have problems with the stock ECU... actually I'm quite sure you will...at least you won't get the optimum out of the parts...
Old Dec 19, 2001 | 06:06 PM
HOK's Avatar
HOK
mmm i don't know... maybe you should invest in researching about tuning and tweaking the engine with the standalone ECU... you may find that you get more power just by tuning the vehicle to its potential... I run high boost and some expert tuners run similar setups WITH less boost and they have more power... something to think about...
Old Dec 20, 2001 | 03:25 AM
Michaelk's Avatar
Yep, my priority would be to get an aftermarket ECU and have it mapped properly, especially as it should be cheaper than pistons anyway and I'm 99% sure the car won't run as well as before you added the pistons, with the standard ECU. I might not even start anymore...
Have a look at www.gems.co.uk and their rally replacement and then there's obviously motec, link, etc...
Old Dec 20, 2001 | 06:21 PM
HOK's Avatar
HOK
mmmm interesting.... WE AGREE!!! hehehee
Old Dec 23, 2001 | 07:54 AM
mouton's Avatar
the sport ecu retards ignition at the top end quite a lot,so i belive you would get away with higher comp at that boost figure
i ran 1.5 without det with std comp,using sport ecu
What have you got the cams dialed in at ?
Old Dec 26, 2001 | 10:55 AM
Prospeed's Avatar
We have done an engine with 10:1 compression ratio. This engine runs with a 34mm FIA restrictor on the turbo. Fuel quality will be a very sensitive point in an engine like this. Dont expect too high boost without using proper racefuel.
Contact us direct if you need help info@autoracing.nu
Regards
PROSPEED
www.autoracing.nu
Old Dec 26, 2001 | 10:41 PM
HOK's Avatar
HOK
none of that octane booster crap too... hehehe with that stuff you might as well put into your car...
mrfred
Jan 6, 2024 09:43 PM
13-0
154
Aug 16, 2015 12:57 AM
Tonba
Jun 14, 2009 05:54 PM
konstantinosIX
Jun 26, 2008 06:29 AM
ambystom01
Jan 20, 2008 01:35 PM
